Old 04-25-2007, 12:33 PM   #1 (permalink)
need-for-speed
Guest
maya need help
i am a pure beginner plz help
how do i reduce the line
like this
Old 04-25-2007, 03:37 PM   #2 (permalink)
need-for-speed
Guest
anyone plxzzzzz
Old 04-25-2007, 10:26 PM   #3 (permalink)
younglion
Guest
i dont understand your question, are you trying to reduce the divisions on the sphere? if you are on the left where is says polysphere click on it and you will see subdivision axis and subdivision(dont remember) you can reduce both
Old 04-26-2007, 02:07 AM   #4 (permalink)
mjgfish
Guest
I don't know much but guessing from what you have said, select your sphere then on your right hand side of maya is information about its position, scale etc. Follow that down until you come to the Inputs section, under that you have polySphere1, click on that. Informtion will pop up and all you have to do is change the numbers in the sections and span boxs.
Old 04-26-2007, 11:31 AM   #5 (permalink)
need-for-speed
Guest
my question was how do i reduce the lines on the sphere because i am following a tut and in the tut the line in the sphere are less than the ones on the top image
top image is my maya
and bottom is the tuts maya
and when i reduce the subdivision and the other thing it is not a sphere it changes to a sphere with coners
Old 04-26-2007, 11:48 AM   #6 (permalink)
It looks like you use a Polysphere, but the tut is using a nurbsphere.
i dont know maya but if you look at the picture you can see it on the right of the picture...Nurbsphere(tut) Polusphere (you).
cheers :)
Old 04-26-2007, 03:23 PM   #7 (permalink)
need-for-speed
Guest
i dont know how to switch between i will try my best and look for a way tro swith but if anyone knows plzz tell me and thanz for the comments
Old 04-26-2007, 03:34 PM   #8 (permalink)
need-for-speed
Guest
i got it to work i went to
Create->NURBS Primitives->Sphere
in the Help-Find Menu
u guys are the man thank u
