Rep Power: 0 ![]() | Maya Bonus Tools 6.5 Doesn't Work Well ! Hi, i used Maya Unlimited 6.5. I installed Maya Bonus Tools 6.5 in the right directory and checked all bonus tools' plug-ins. Maya starts with no error messages... but a lot of tools doesn't work like "Edge Path Selection Tool", "Toggle Face Display", ... with dis kinda messages : For example : "Edge Path Selection Tool" // Error: -onc "optionVar -iv QT_edgePathAutoComponentConvert 1; \ // // Error: Unterminated string. // // Error: -onc "optionVar -iv QT_edgePathAutoComponentConvert 1; ... Second Kinda Example : "Toggle Face Display" // Error: Cannot find procedure "doMenuComponentSelection". // I don't know whatz wrong :/ I check lots thing... with the docs but i didn't find a way to solve it. (I use the userSetup dat comes from BonusTools). HELP ME!!! |
Rep Power: 0 ![]() | I installed Maya Bonus Tools 6.5 here : /Users/Shared/Alias/maya/6.5 Maya > 6.5 > > data > > docs > > icons > v mudules > > plug-ins > > scripts > > skeletons ///////////////// MY userSetup.mel > /Users/kurl/Library/Preferences/Alias/maya/6.5/scripts/userSetup.mel MJPolyTools; cpsInstallMenu; //////////////////////////////// // bonusTools userSetup.mel //////////////////////////////// // // if you have an existing userSetup.mel file you will need to append // this code to have all the bonusTools available // cut and paste the contents of this file into your existing userSetup.mel // and restart maya to get the full effect // scriptJob to rebuild menu as working mode changes scriptJob -permanent -event "MenuModeChanged" "bonusToolsMenu"; // build the menu the first time bonusToolsMenu; // publish (ctrl+RMB in channelBox) // aka Quick Connect Attributes // uncomment the next line if you wish to use this functionality //publish; // shift + rmb poly context sensitive marking menu // the following lines allow you to take // advantage of it - comment them out or remove them // if you do not want this functionality string $btPath = `whatIs bonusToolsMenu`; int $numCharacters = `size($btPath)`; $btPath = `endString $btPath ($numCharacters-24)`; $numCharacters = `size($btPath)`; $btPath = `substring $btPath 1 ($numCharacters-18)`; $btPath = ($btPath + "ModelEdMenu.mel"); eval( "source \"" + $btPath + "\"" ); /////////////////////////////////// // end bonusTools userSetUp.mel /////////////////////////////////// |
Rep Power: 0 ![]() | Hi all, I think i know where's the problem. I was looking for installing Bonus Tools 6.5 correctly following the Wavefront How To but nothing works... so i move the BT's repertories inside /maya/6.5 (from the users/share path) but like you i noticed lots errors like Syntax Error and some Missing Procedures. I sourced theses procedures but for the syntax errors the problems still. I try to send any messages on several forums but no one know how to solve the problem. I get the BT for windows and check if there is a difference > no differences. So i looked inside the scripts like "EdgePathTool" and i find what is wrong : Maya doesn't support when a line finishes with "/". "/" is use to use a symbole like " without use it. So when a line finish with "/" the "return" symbole doesn't appear at the end after the "/" and maya think something is missing. So i deleted all "returns" after "/". And the script works correctly. Its amazing windows users don't have this problem. Its surely a translation caracter problem. But i don't know why any procedures are not sourced like "doMenuComponentSelection" (you can find it in maya.app/content/script/others)... It would be fine if some Maya's developpers can answer to these questions. Its a long time Maya Bonus Tools is online.. and we are all waiting for soltutions. Thanks to them to help us. :-) |
