Old 02-17-2008, 04:57 AM   #1 (permalink)
Moderator
bajicdusko's Avatar
Rep Power: 0 bajicdusko is on a distinguished road
Emitter - Poly surface
How to connect existing emitter to poly surface, so they can move together.
Don't worry about thing, 'cause every little thing is gonna be allright"
Bob Marley
bajicdusko is offline   Reply With Quote
Old 02-17-2008, 06:02 PM   #2 (permalink)
pedrobellini
Guest
Hi again man, what up??
so, you could try this one: select the geometry, than shift select the emiter... If you want to the emiter move with the geometry, but at relative positioning than hit "p" (is parent constraint) if you want the emiter to be at the pivot of the object and move with it, always in the pivot than you should select the point contraint...
those can be found in animation tab (F2) at constrain.
if you want to remove the constrain open the outliner (at window), select the emiter and delete the constrain...
so, tell me if it's working!
Old 02-17-2008, 06:21 PM   #3 (permalink)
pedrobellini
Guest
Ok, lets try something else too, but the result is the same as point constrain... its good to know...
Go to: Window -> Genereal Editors -> Connectin Editor
select the geometry, the poly surface, and hit "reload left" (upper left of the window), then select the particle and hit "reload right".
OK, now you have the objects, so what is left to do is connecting them... so, LMB (just once) click on the translate of the poly object and then LMB click on the translate parameter of the emiter (just once too) and there you go, there is a connection
The Following User Says Thank You to For This Useful Post:
bajicdusko (02-18-2008)
Old 02-19-2008, 07:00 AM   #4 (permalink)
Moderator
bajicdusko's Avatar
Pedrobellini's pictures of Point Particles. Thank you man.
the picture 3" has fine tracing option and the picture 4" is at draft quality setting
Thank you man.
Emitter - Poly surface-picture_2.jpg   Emitter - Poly surface-picture_3.jpg   Emitter - Poly surface-picture4.jpg
Bob Marley
Old 02-19-2008, 11:02 AM   #5 (permalink)
pedrobellini
Guest
yeaah man, thanks for uploading the pictures! i couldnt do it here... =)
