Old 04-23-2008, 01:42 PM   #1 (permalink)
Rep Power: 0 LokArt is on a distinguished road
Dynamics: Particles
Hey.
I'm working on a project where I need to be able to control the speed of particles emitted from an emitter and the speed at which they are emitted. Essentially so I can slow them down or speed them up simultaneously.
I tried keying the speed attribute in the emitter tab, but it does not effect the speed of particles already in the scene. No luck with the conserve attribute either.
So I was wondering if anyone knows of a solution or if there is a plug-in or per-particle script that would help. I'm using Surface Emitter as well as Curve and Surface Flow.
LokArt is offline   Reply With Quote
Old 04-27-2008, 12:10 PM   #2 (permalink)
pedrobellini
Guest
I guess you can use a velocity per particle linked with the time or frame, maybe with the "sin" so it gets fast and slow...
For a simple acelleration you could use something like this:
particleShape1.velocity=<<10*(time),0,0>>
Old 10-11-2008, 11:46 PM   #3 (permalink)
Rep Power: 0 ruchit is on a distinguished road
hey,which emitter u use in ur scene
ruchit is offline   Reply With Quote
Tags
emitter, particles, speed
