Old 01-05-2008, 05:17 AM   #1 (permalink)
Calliopeia's Avatar
Rep Power: 0 Calliopeia is on a distinguished road
Question Add a face between vertex without extrude?
Hey guys!
Could you please help me? I'm quite new to this 3D and because of this I have some maybe from your view seen, stupit questions.
My question is: Can I add a face between vertexes without extruding and then connecting points? This would save a lot of trouble and time for me.
Please help. I'm currently working in MAYA 8.5.
Thank you in advance!
Best regards Veronika
Calliopeia is offline   Reply With Quote
Old 01-05-2008, 06:23 PM   #2 (permalink)
PolygonJunkD's Avatar
Rep Power: 0 PolygonJunkD is on a distinguished road
hey veronika.
hmm, if i get you right, you want to cut a face in the middle right in the middle don't you? I mean, if you want to have a new face between two vertecises it should be that.
Si i would guess you should try the "Split Polygon Tool". Hopefully this works fine for you.
Cheers,
Poly.
if you are bored it just means that you're NOT creative!
So go, and be creative - loser !
PolygonJunkD is offline   Reply With Quote
The Following User Says Thank You to PolygonJunkD For This Useful Post:
Calliopeia (01-07-2008)
Old 01-06-2008, 03:11 AM   #3 (permalink)
Rep Power: 0 potryvayev is on a distinguished road
You can add a face between vertexes using this tools:
1) Fill Hole command (in Polygons menu -> Mesh -> Fill Hole)
Sometimes after this command you have to add edges if your get non-planar N-gones. You can do this using this tool: Split Polygon Tool (in Polygons menu -> Edit Mesh -> Split Polygon Tool)
2) Create Polygon Tool (in Polygons menu -> Mesh -> Create Polygon Tool)
In this case use V button pressed on the keyboard to snap to the vertexes. And after that tool you have to combine your mesh with new polys you've created and merge separated vertexes.
So, maybe this help you! Good luck!
potryvayev is offline   Reply With Quote
The Following User Says Thank You to potryvayev For This Useful Post:
Old 01-07-2008, 05:05 AM   #4 (permalink)
Calliopeia's Avatar
Thank you!
Thank you!!!
I will try all your suggestions! :-)
Millions of thanks!
Br Veronika
